Kihasználatlanság miatt eladó kb. 1 évet futott Qnap TS431xeu NAS, 8GB ram, SFP kábel.
Ár: 160000 ft.
Igény esetén tudok mellé adni 3x3TB Toshiba HDD-t és/vagy 250GB Samsung SSD-t. (ez természetesen egyedi árat képez)
CPU Annapurnalabs Alpine AL314 32-bit ARM Cortex-A15 quad-core 1.7GHz processor
CPU Architecture 32-bit ARM
Memory Slot 1 x SO-DIMM DDR3
Flash Memory 512MB (Dual boot OS protection)
Drive Bay 4 x 3.5-inch SATA 6Gb/s, 3Gb/s
Drive Compatibility 3.5-inch bays:3.5-inch SATA hard disk drives
2.5-inch SATA hard disk drives 2.5-inch SATA solid state drives
Hot-swappable Yes
SSD Cache Acceleration Yes Support
Gigabit Ethernet Port 2 (RJ45)
10 Gigabit Ethernet Port 1 x 10Gbe SFP+
Wake on LAN (WOL) Yes
Floating Point Unit Yes
Encryption Engine Yes
System Memory 8 GB Sodimm DDR3 (1 x 8 GB)
Maximum Memory 8 GB (1 x 8 GB)
Jumbo Frame Yes
USB 3.2 Gen 1 port 4
Form Factor 1U Rackmount
LED Indicators HDD 1-4, Status, USB, LAN1-3
Buttons Power, Reset
Dimensions (Hxwxd) 44 × 439 × 291 mm
Weight (Net) 4.15 kg
Weight (Gross) 5.78 kg
